Hold Attribute Value with Solver
Hey guys!
I'm trying to wrap my head around the solver sop.
I have an alembic geometry that needs an attribute for the frame any point started changing position.
What I tried was, inside a Solver SOP, appending a Point VOP where I subtract the rest position from the new one, compare the length of that delta and then write the frame on an attribute.
The test and such works fine, but then my frame keeps changing, which I understand that it happens because I haven't figured a way to stop the value from changing.
What I'm trying to achieve is to do a color ramp on the points by the attribute that tells which frame started moving. Any help will be very much appreciated!
20200316_CubeAnimation.rar
Thank you very much for the guidance and the help, I understand much better know how the workflow should be prepared for this. I didn't thought about the initialization of the value, so I'll keep in mind that for the next time I run into this.
Really appreciate the time and examples, cheers Srdjan!
