How can you make a surf wave?
You might try the Beach Tank tool in the Oceans tab for a basic setup doing something similar. This should give you an idea of how to do it with FLIP. If you want to do it with surface deformations, the problem is having your wave crash back into the water will be next to impossible to implement.
In this SideFX Masterclass, they are describing the technique using surface deformation a little bit. This should give you an idea of how to do it:
