H18 external editor bug?
Has the external editor setup changed in H18? I no longer see the button in the UI. I have set the .env to use both EDITOR and VISUAL both separately from one another. Neither seems to do the trick, but I'm guessing the button no longer exists, and if read properly it will just open the editor on first edit, unlike the past versions of Houdini.
Thanks
Edited by Readicculus
