FK IK match script error
Been trying to rig in Houdini, went through the rigging series which was decent but the script for Matching FKIK comes up with an error when I execute it.
If you didn't see the video series. This is on the last video. Inside the HDA there is a parameter button created with the callback script  hou.pwd().hdaModule().matchIK(kwargs,"arm")
This is the code
def matchIK(kwargs,type):
    if kwargs["script_parm"][0] == "L":
        side = "L"
    else:
        side = "R"
    prefix = side + "_" + type
    asset = kwargs["node"]
    bone1 = hou.node(asset.path() + "/" + prefix + "bone_1")
    bone2 = hou.node(asset.path() + "/" + prefix + "bone_2")
    fkcontrol1 = hou.node(asset.path() + "/" + prefix + "_bone_1_ctrl")
    fkcontrol2 = hou.node(asset.path() + "/" + prefix + "_bone_2_ctrl")
    fkcontrols = [fkcontrol1, fkcontrol2]
    bones = [bone1, bone2]
    if type == "leg"
        prefix = side + "_" + "foot"
        bone3 = hou.node(asset.path() + "/" + prefix + "_bone_1")
        bone4 = hou.node(asset.path() + "/" + prefix + "_bone_2")
        fkcontrol3 = hou.node(asset.path() + "/" + prefix + "_bone_1_ctrl")
        fkcontrol4 = hou.node(asset.path() + "/" + prefix + "_bone_2_ctrl")
        bones.append(bone3)
        bones.append(bone4)
        fkcontrols.append(fkcontrol3)
        fkcontrols.append(fkcontrol4)
    for i, fkcontrol in enumerate(fkcontrols):
        curbone = bones
        bonepath = "/".join(curbone.path().split('/')[2:])
        iksolver = curbone.node(curbone.parm("solver").eval())
        chopstring = 'chop("' + iksolver.path() + '/' + bonepath
        chans = ["rx", "ry", "rz"]
        for chan in chans:
            if abs(hou.hscriptExpression(chopstring + ':' + chan + '")')) < 0.0001:
                rot = 0.0
            else:
                rot = hou.hscriptExpression(chopstring + ':' + chan + '")')
            if not fkcontrol.parm(chan).islocked():
                fkcontrol.parm(chan).setPending(rot)
Error says line 16, in matchIK
AttributeError: 'NoneType' object has no attribute 'path'
Im fairly clueless when it comes to scripting just wanted to be able to match IK Fk.
Help would be appreciated as would any advice on places to start with python scripting.
Many thanks,
Duncan
  • 2 months later...
Just make sure you are accurate with your typing out.
The line above it has an error which prevents working through the list of bones.
curbone = bones
It should be:
curbone = bones[i]
Edited by DaFiNNiGaN
