kittea Posted April 26, 2020 Share Posted April 26, 2020 Using Houdini v18.0.447. I can't get chramp to show a ramp in the parameters of a wrangle node. If I load up existing projects with a ramp, it shows up. However, in a new project, it does not appear. In the existing project, I've also added a new AttributeWrangle node, copied the same code, hooked things up, and the ramp does not appear. I've also installed and tried v18.0.416 but got the same results, no ramp. Is this a bug or a setting that I accidentally turned off? chramp_test.hipnc Quote Link to comment Share on other sites More sharing options...
kittea Posted April 26, 2020 Author Share Posted April 26, 2020 Oh jeez, never mind. I figured out I need to click that little button on the right for spare parameters. Quote Link to comment Share on other sites More sharing options...
