HappehLemons Posted May 23, 2020 Share Posted May 23, 2020 (edited) I have a deforming collider with a Flip Fluid being emitted on it. It has some small movements to it but nothing too drastic. It almost works well, but for some reason particles seems to "randomly" appear in locations where they're not being emitted. What's causing these particles to suddenly appear? I'd like to kill them in some kind of automated way, but I'd also like to understand why it's happening. I'm using almost completely default settings but I have: Change the grid size Increased sub-steps Made sure my collision object was water tight Increased particle separation (This seemed to make the issue MUCH more visible actually) Kill droplets (This seemed to kill way to much and left a lot of the stray particles) Disable reseeding Here's an example of what I'm talking about (These screen caps are 1 frame apart) Edited May 23, 2020 by HappehLemons Quote Link to comment Share on other sites More sharing options...
HappehLemons Posted May 24, 2020 Author Share Posted May 24, 2020 (edited) Is there a method for killing particles with sporadic movement? The thing that confuses me most is if reseeding is off, that would mean these particles are coming from somewhere, but they truly look like they're being generated somehow since they continue to appear on top of my collision object? Perhaps previously trapped inside my collision or something and being moved to the top of the object. Worst case I could find a method to manually remove them I suppose. I tried grouping and deleting them outside of the POPnet but since the particle numbers are changing they reappear next frame. Any help with either of those methods would be awesome. Edited May 24, 2020 by HappehLemons Quote Link to comment Share on other sites More sharing options...
