Color disappears after adding instancefile
Hi, sorry if this has already been asked haven't been able to figure it out. Is there a way to keep your color after creating an @instancefile attribute? To clarify, I'm using Redshift and when I create an @instance attribute and point it to my object the objects @Cd will come through in the render, as long as the object the @instance attribute is pointing to is using a shader that has an RS point attribute node plugged into it. However, if I create an @instancefile attribute instead and point it to the .rs file I exported to my harddrive it will not show this color. Is there a trick to getting this color to show? thanks.
