gabriel101x Posted June 2, 2020 Share Posted June 2, 2020 (edited) Hi all so I'm new to Houdini and having an issue with using the Debris shelf tool on an RBD sim and was wondering if anyone could shed some light. It works fine when just sourcing it from the DOP import node coming out of my sim, but whenever I cache out the sim and set to load from disk I get invalid source errors in the debris source geo network. Am I doing something wrong when caching out my sim? The geometry loads in just fine, it's just the debris source that can't read it, tried with filecache node, DOP IO and also just caching out then using plain file node set to read, all have the same problem. Attached a lightweight example project bellow where I recreated the problem. Houdini_Debris_Tool_Cache.zipFetching info... Edited June 2, 2020 by gabriel101x Quote Link to comment Share on other sites More sharing options...
JohnyCash Posted September 1, 2021 Share Posted September 1, 2021 hello. in rbd i/o in load from file tab set cache frames to smth like 3. in my case it worked Quote Link to comment Share on other sites More sharing options...
