DesbiensAntony1997 Posted June 8, 2020 Share Posted June 8, 2020 Am trying to have some light coming out from my particles and i am using a geometry light But i can't even see the reflection on the ground, i just have a little bit on my subject. I've also tried to use a sphere and copy to points with my particles but the result is very unnoticeable. Magician_Particles_V34.hipnc Ganfaul.abc ( Geomerty in the Character Animation Node ) Quote Link to comment Share on other sites More sharing options...
ziconic Posted June 28, 2020 Share Posted June 28, 2020 I'm guessing you've probably already figured it out by now but you don't actually have any geometry lights set up in your hip file. Also note that you can't set up a geometry light from points alone. You have to have some sort of primitive geometry, e.g. polygons, line segments, volumes. Copy to points using a sphere should have worked though (but would be very inefficient). Quote Link to comment Share on other sites More sharing options...
