Finding nodes with given value in any parameter
Ctrl+F has raw parameter filter that helps to find a node with the given value in a specific parameter. I was wondering if there was a way to search for the given value in any parameter? I didnt find any solution, maybe its because it would be too heavy to look in every parameter, but I thought Id try to ask, maybe you guys know.
Ithe only partial solution I sound was in python to loop nodesearch.RawParm() over the parameter names I want. But some times you dont know the parameter name so it would be nice to be able to find it anyway.
Thanks
Martin
  • 1 year later...
I had the same issue. Support confirmed that this was a bug.
It is not yet implemented in stable build 18.5.596 but in daily build 18.5.629 you can now search all parameters via the raw parameter filter like for example
 Raw Parameter * contains $FOO
