Blend Sop With Kernel Fallof?
MADjestic
Hi there,
I need a tool similar to Blend SOP, but with an ability to restrict the blending to certain parts of the geometry bounded by a soft radius - i.e. the parts of the geometry that are further from the kernel of blending are effected, while the points of the geo that are closest to the kernel are blended the most - so that there was a nice controllable falloff of blending effect.
Any simple solutions?
I'm not sure exactly what you're looking for, but here's a trivial
little VEX function which blends between two pieces of geometry based
on a smooth rolloff from the center point.
sop
mblend(vector center=0; float radius=1)
	vector	p1;
	float	factor;
	// Get the position of the second input
	if (!import("P", p1, 1))
	p1 = P;
	// Compute the blending factor
	factor = smooth(0, radius, length(P-center));
	// Now, do the blending.
	P = lerp(P, p1, factor);
Just skimmed through Exchange and saw Simon's Soft Blend otl - maybe this will suffice what I need, or will set me on track.
http://www.sidefx.com/exchange/info.php?fi...p;versionid=105
sop
	vector	p1;
	float	factor;
	p1 = P;
Yeah Crunch - more or less I was thinking about similar solluton. Thank you.
So there are noready-made sollutions? It's ok - just didn't want to reinvent another bicicle.
I just whipped up a quick hip before I noticed these replies and it's along the same lines as Simon's blend OTL which I'd forgotten about!! Here it is for comparison in case this is any use. I painted a control area, used an attribute transfer to get the falloff and a point SOP to do the blend. It's basically a 3-node solution.
softBlend_jsh.hip
  • 3 weeks later...
