xxmarkc Posted August 5, 2020 Share Posted August 5, 2020 (edited) I have been migrating a tutorial from Mantra to 3Delight. There is a limited number of 3Delight nodes you can use in a mat context. I was hoping you could mix houdini nodes with the 3Delight nodes: e.g. do some calculation to build say a value for the vector colour attribute, then convert the vector to 3 floats, the use the 3Delight FloatToColour node to build a 3Delight Colour object. The nodes join, types match i.e. the output of the Manta node is floats the input to the 3Delight node is floats, but the values get ignored. It is not clear to me if this is because 3Delight is still Beta so not everything works as expected - or if by design this plugging of nodes is just never going to work? I would imagine the Houdini node interpreter would have no problem passing the float along so it must be 3Delight that is failing to get the plumbing to work. The is a question in principle since i have worked around in 2 ways: 3Delight has a (horrible) condition node that can be used for the logic I needed (but doing so involves you implementing the logic 2x - once for Mantra once for 3Delight). My second solution was to take the nodes out of the mat context and put them in a VOP in the obj context and set a attribute. In the mat context you just then read the attribute using the supplied 3Delight node. This either means you end up with duplicate code in the obj context for 3Delight, and the mat context for Mantra, or you move shader logic out of mat context - which seems to be taking it away from where it should be. I wanted thought to have a set up that had a switch to flick to move from Mantra to 3Delight and to share the Mantra logic as much as possible in the mat context. Edited August 5, 2020 by xxmarkc re-word. Quote Link to comment Share on other sites More sharing options...
