karlos_the? Posted October 27, 2006 Share Posted October 27, 2006 Hi, I feel a bit like a fool here. I would like to use the the terragen sop and have downloaded the files. I guess i need to compile them but don't know where to start. A few pointers would be great, or a compiled version! Thanks Karlos Quote Link to comment Share on other sites More sharing options...
MADjestic Posted October 29, 2006 Share Posted October 29, 2006 Hi,I feel a bit like a fool here. I would like to use the the terragen sop and have downloaded the files. I guess i need to compile them but don't know where to start. A few pointers would be great, or a compiled version! Thanks Karlos I guess nobody answers because you are asking the stuff so basic that helping you would be called spoonfeeding. How about atarting from reading wiki/Help (typing HDK in both)? I hope I don't sound rude =) Quote Link to comment Share on other sites More sharing options...
jhiggins Posted October 31, 2006 Share Posted October 31, 2006 I guess nobody answers because you are asking the stuff so basic that helping you would be called spoonfeeding. How about atarting from reading wiki/Help (typing HDK in both)?I hope I don't sound rude =) as MADjestic suggests, search for HDK. you'll first need to setup you're development environment for using the HDK and there should be instructions to do that there. Once thats setup, you should just be able to run hcustom SOP_TerreGen.C which if everything is setup properly then it should build with no errors (probably some warnings) and be available for you when you run houdini. hope the helps! Quote Link to comment Share on other sites More sharing options...
karlos_the? Posted November 1, 2006 Author Share Posted November 1, 2006 Thanks for the replys I will start my reading Karlos Quote Link to comment Share on other sites More sharing options...
