Material Stylesheet Condition - Value limitation ?
  I am experimenting using Material Stylesheet in assigning shaders to prim group in packed primitive.
  I am using the Moana Island dataset as my experimental input and hence their prim group names (which contains number)
  I noticed that if I use wild card to match the names and skip the numbers, the material assignment is successful whereas if the value contains numbers, the match does not succeed and hence the assignment is not perform.
  Is this a known limitation or a bug ? I am very new to material stylesheet usage.
Cheers
