CTW Posted October 2, 2020 Share Posted October 2, 2020 Hi, I'm having difficulty controlling the scale and rotation of several objects using RBD sim. I can controlling scale by using ident matrix, but if I control rotate, error occurs that the objects changing lager of smaller. also w attribute is executed separately for rotate, but w attribute and ident scale matrix are not executed at the same time.... Does anyone know how to fix this problem?? Thank you so much if you let me know! Quote Link to comment Share on other sites More sharing options...
toadstorm Posted October 2, 2020 Share Posted October 2, 2020 The `transform` 3x3 matrix intrinsic controls both rotation and scale. If you're assigning rotations based on quaternions, you're going to run into scale issues because quaternions can't contain scale information. The `w` attribute is for angular velocity, not rotation, so it won't help you here. What you can do is use cracktransform() in VEX to extract the scale from a matrix as a vector, then use the `scale()` VEX function on your rotated matrix to scale it back to the original value, either before or after your rotation (depending on whether you want your scaling to happen in world or local space). You could also consider using MOPs Apply Attributes to handle this for you. 2 Quote Link to comment Share on other sites More sharing options...
CTW Posted October 3, 2020 Author Share Posted October 3, 2020 18 hours ago, toadstorm said: I've been looking for cracktransform, but it's a bit difficult, so i'll have to think about it while looking for examples. Thanks to that, I knew how to approach it. I really appreciate it! Quote Link to comment Share on other sites More sharing options...
