dmv096 Posted December 16, 2020 Share Posted December 16, 2020 Hi, this is a basic question but I have spent hours and didn't see the answer anywhere. I have some geo packed and ready for a rigidbody simulation, but i want to cotrol when the geo start to simulate. So I put a wrangle node to control it, for example: I want to start in the third frame: i@active=0; if ($F>3){ i@active=1; } But in the Dopnet, it never starts. In the spreadsheet active keeps 0 and never changes to 1. I tried to put the wrangle in a solver (because it worked for me with working with attribute transfers stuff) but it didn't work either. I did a simple scene with the problem. P.S. I know I can change the frame of the start of the sim but actually i would like to have diferents objects with differents starts so I though @active is the way. Thanks in advance active_update_question.hipFetching info... Quote Link to comment Share on other sites More sharing options...
ikoon Posted December 16, 2020 Share Posted December 16, 2020 Hi Davis, you had a wrong syntax in your "set_active" wrangle I commented your line and added a right one: i@active=0; // if ($F>3){ if (@Frame>3){ i@active=1; } Quote Link to comment Share on other sites More sharing options...
dmv096 Posted December 16, 2020 Author Share Posted December 16, 2020 On 12/16/2020 at 2:32 PM, ikoon said: Hi Davis, you had a wrong syntax in your "set_active" wrangle I commented your line and added a right one: i@active=0; // if ($F>3){ if (@Frame>3){ i@active=1; } Expand Oh, that was it! Now it works elegantly. The variables and attributes are going to kill my health. Thanks a lot, I owe you one. 1 Quote Link to comment Share on other sites More sharing options...
ikoon Posted December 16, 2020 Share Posted December 16, 2020 Well you are right, that it looks like it should work ... but it doesn't maybe it is a bug and your syntax is ok? Btw you can evaluate the parm by middle clicking on its name (VEXpression), the parm is then in dotted line: 1 Quote Link to comment Share on other sites More sharing options...
dmv096 Posted December 16, 2020 Author Share Posted December 16, 2020 On 12/16/2020 at 2:46 PM, ikoon said: Well you are right, that it looks like it should work ... but it doesn't maybe it is a bug and your syntax is ok? Btw you can evaluate the parm by middle clicking on its name (VEXpression), the parm is then in dotted line: Expand Ohh nice tip! Well from now on I will use @Frame instead of $F in cases similar to this one and I will save myself headaches. Thanks again! Quote Link to comment Share on other sites More sharing options...
