jttarigan Posted January 11, 2021 Share Posted January 11, 2021 Greetings, I have a problem with applying copy to point. Basically, I want my copied polygon to follow the curve orientation/direction. The network is simple ( I followed a tutorial from youtube) The polyframe node generates N values from the tangent value. I've checked the normal and the values in the spreadsheet, there seems to be no problem with the N values. This is the result that I expect to get: However, in my scene, the copied objects seem to rotate along the normal axis of the point, as the image below: Any idea what's wrong with my scene? Thank you in advance. Quote Link to comment Share on other sites More sharing options...
