starion83 Posted February 14, 2021 Share Posted February 14, 2021 In a dopnet I'm trying to weight the amount that of force that is applied by a pop advect by volumes in a, based off attributes that change over time. So the geo that is advected changes over time. I've had success achieving a similar weighting with a pop force with VEXpressions, however this requires the input tab in the node to specify the geo to specify a SOP path to read the attrib values from. And the pop advect by volumes node doesn't have this. Not sure how to implement the same approach without this! Thanks for any help you can offer! Quote Link to comment Share on other sites More sharing options...
k2p8 Posted February 14, 2021 Share Posted February 14, 2021 If you unlock the popadvect node you will find a popvop inside. You can acces inputs in there and modify the popvop to match your desired effect. 1 Quote Link to comment Share on other sites More sharing options...
starion83 Posted February 14, 2021 Author Share Posted February 14, 2021 1 hour ago, k2p8 said: If you unlock the popadvect node you will find a popvop inside. You can acces inputs in there and modify the popvop to match your desired effect. Ah! Amazing! I hadn't unlocked a node before. That worked perfectly. Thanks for the tip! Quote Link to comment Share on other sites More sharing options...
