BrianK Posted December 5, 2006 Share Posted December 5, 2006 I've made an animation at NTSC, 30fps. I now want to make it NTSC, 60fps interlaced. Is there a somewhat simple way to do this? I don't see the "Fields" section in the mantra ROP. ?? Quote Link to comment Share on other sites More sharing options...
stu Posted December 6, 2006 Share Posted December 6, 2006 Field Split COP? Quote Link to comment Share on other sites More sharing options...
BrianK Posted December 6, 2006 Author Share Posted December 6, 2006 Field Split COP? If I'm not mistaken, the feild split pop just splits one progressive scan frame into two interlaced frames - which does answer the question I asked but... I need to render to each field - a different image on each field. I've just decided to double the frame rate & take care of fields in post... Unless someone else has a better idea. Quote Link to comment Share on other sites More sharing options...
digitallysane Posted December 6, 2006 Share Posted December 6, 2006 From the journal Monday, July 10, 2006Houdini 8.1.659: Mantra now supports rendering fields again. Field rendering is controlled through the ray_field command in the IFD. * Render both fields: ray_field 0 * Render odd field: ray_field 1 * Render even field: ray_field 2 Dragos Quote Link to comment Share on other sites More sharing options...
