MADjestic Posted December 16, 2006 Share Posted December 16, 2006 Hi there, I've got the following problem - the same expression, entered in textport and in an expression field returns different results, here's the sample code, illustrating the issue: dopobjectlist("/obj/dopnet1", dopoptions("/obj/dopnet1", "Obj8","Position","glueobject"), 0) Entered in the textport, analogous echo `dopobjectlist("/obj/dopnet1", dopoptions("/obj/dopnet1", "Obj8","Position","glueobject"), 0)` returns 38, as expected- while the Expression field always returns 0. What is the reason of that? Thanks. P.S. I am trying to input this in Modify Data DOP node, float field. Quote Link to comment Share on other sites More sharing options...
