Only allow HDA inputs of a particular node type
haki
Hi Hristo,
yes you can.
With a Python node as the first node in your HDA, you can fetch the input node's type, and check if it is a type you want or not.
In the example below, I check against a list to see if it is a type I don't want. The opposite would be easy to implement.
wrongTypes = ["add", "box", "testgeometry_pighead"]
node = hou.node(".").inputs()[0]
nodeType = node.type().name()
#print(nodeType)
for type in wrongTypes:
    if nodeType == type:
        raise hou.NodeError("Node \"%s\" not compatible !" % nodeType)
This method might not be the best, since if the input is animated, the Python node will evaluate at each frame.
Since you have an HDA, you could go into the Type Properties, Script, then add an Event Handler "On Input Changed", and run (almost) the same code. That should be cleaner.
errorOnInputNodeType.hipncFetching info...
EDIT :
Here's the code to do the opposite, to keep only the nodes for which the type has been specified.
goodTypes = ["add", "box"]
#print(nodeType)
found = 0
for type in goodTypes:
        found = 1
        break
if found == 0:
Edited by Alain2131
  • Thanks 1
Hi Alain,
This is fantastic! Much appreciated!
I played around a little to find a way to get the error message to propagate upwards without throwing to the consol onInputChanged.
I combined the 2 methods you wrote about (thanks for the great detail btw!). I left the python SOP alone in a separate branch and I run the cook() method on it onInputChanged. I don't know if that takes care of the cook-on-every-frame issue.
This is what I've got: https://github.com/arabadzhiyski/update_curve_coordinates
It must be the most useless, useful thing I've done yet..
Thanks again,
Hristo
Hey Hristo,
That's pretty cool !
I like your Try Except to set the switch as a workaround to "Error while cooking."
Yet another way to do it would be to make the check in onInputChanged, and if problem, switch to the input 0.
In the input 0, you can put an error node with your message. That way, it doesn't have the "Error: Error generated by python node."
update_curve_coords.hdaFetching info...
P.S. Nice cloud =P
Edited by Alain2131
  • Thanks 1
