Ambient()
B.Walters
As a wonderful Christmas present, I received the Advanced Renderman book and I've been plowing through it full-speed. Now that I'm back at home/work, I've been trying to actually implement a lot of the shaders in VEX (mostly from memory to see if I really understand them). But I hit a problem-spot early on with the ambient function.
Here's what I've tried:
  Quote
vector my_ambient()
vector C = 0;
illuminance(P, N, PI*2, LIGHT_AMBIENT)
C += Cl;
return C;
The problem is my_ambient always returns 0 - no lights are getting passed through the luminance loop. If I change the argument LIGHT_AMBIENT to LIGHT_AMBIENT|LIGHT_DIFFUSE|LIGHT_SPECULAR - then it will loop through any other normal lights I have in the scene (and sum up their values), but still not the ambient light.
So I know it's something small/simple, but I can't figure it out. By the way, is there anyway to see what Houdini's built-in ambient() looks like?
An ambient lights is a different object type than a normal light and, as in PRMan, the only way to access its contribution is through the built-in function "ambient()". So your my_ambient() function would simply forward the call to the built-in one (not very useful except as an exercise):
vector my_ambient() {
   return ambient();
IOW: ambient lights are not iterated over in an illuminance loop. Instead, their contribution is fetched using the ambient() function.
However, this doesn't mean that you can't have a normal light that behaves like an ambient light and that will show up in normal illuminance loops. The following *light* shader is an example:
light my_ambient(
	  vector lightcolor = 1;
	  float  intensity  = 1;
   Cl = lightcolor*intensity;
   L  = 0;
If you assign this last shader to a normal light, it will show up in an illuminance loop (due to the fact that it is a light object as opposed to an ambient light object), and it will emulate the behaviour of a standard ambient light (in terms of shading).
HTH.
P.S: Happy New Year Everyone! :)
Actually, I think this was a bug in H8. I think it works in H9 (from what a little bird tells me).
