Latimerias Posted July 22, 2021 Share Posted July 22, 2021 Hello, So i import data with varying attribute values. For example ill call it attribute "Type" with string values "B,F,C,D". The attribute always imports under the name type but the values change, im looking for a way to generate a color parameter for each value so i can color value "F" primitives a different color than "B,C,D". The problem i cant get around is if the next dataset i import has values "X,A,S" how can i make the interface dynamic so that now i only have color parameters for the X,A,S values. The closest thing i can find is multiparam blocks but those would require me to manually create the parameters where instead i want parameters to generate based on the number of attribute values. I hope this made sense, thankyou for your time! Quote Link to comment Share on other sites More sharing options...
