add noise to points but only in x and y axis
rickvdvulkaan
For modeling purposes, i want to add some noise to the position of the points, but without affecting the Z axis. So i tried the mountain SOP first, but i found no options to exclude the z axis. so i tried vops, with the noise and add node, but as expected this adds noise to all directions. I'm kind of stuck, as i'm still a beginner. Can someone point me in the right direction?
Point Jitter SOP - axis scale z: 0
OR
Attribute Wrangle (Run Over Points):
Remember to click the little icon to create the parameter.
vector noise = noise(chv("offset")+@ptnum);
noise.z = 0;
@P += noise;
As with most things in Houdini, there are infinite ways to achieve a given effect.
Edited by Fenolis
