Starrider Posted September 8, 2021 Share Posted September 8, 2021 Is there a way to 'push' the file chooser button of a file parameter via python? Use case: user selects a folder preset (texture, fx, model) from a list and after selection it prefills a target folder (/assets/models) but opens that same file chooser so the user can pick the final path (select/add extra subfolders etc.) I guess I could run an individual file path dialog and fill the result into the parameter. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
