nicholas_yue Posted September 25, 2021 Share Posted September 25, 2021 I would like my file chooser in my C++ SOP plugin to only show up certain file extensions. What is the recommended way ? Quote Link to comment Share on other sites More sharing options...
forever_kk Posted January 5, 2023 Share Posted January 5, 2023 static const char* theDsFile = R"THEDSFILE( { name parameters parm { name "shpfile" // Internal parameter name label "SHP File" // Descriptive parameter name for user interface type file default { "" } // Default for this parameter on new nodes parmtag { "autoscope" "0000000000000000" } parmtag { "filechooser_pattern" "*.shp" } parmtag { "import_token" "shp_file" } } } )THEDSFILE"; most important is "parmtag { "filechooser_pattern" "*.shp" }" you can change *.shp to any format you want Quote Link to comment Share on other sites More sharing options...
