[FLIP SIM] Initial Particle viscosity attributes stuck at 0
TinFoil
Heyo, first time on this forum so hopefully I'm doing this correctly :P
I have a basic flip sim setup where I would like to control the viscosity based on time and age ( as from some popular tutorials online).
However, I'm stuck on the problem that the first creation inital particles have their viscosity stuck at 0, even if I have a constant value in the viscosity attribute at 10000 (as a test).
I believe this is an issue with particle seperation of the flip source or flip object within the dop net. I found that increasing the particle seperation in the flip object and decreasing in the flip source fixed those initial particles, but then I run into the issue of having too many gaps between particles.
What's even more strange is I have a 1-1 setup from a tutorial setup with the same values, yet I'm running into these issues.
I have included the hip file if anyone is able to help me out with this.
Thanks!!
* Viscosity not velocity in the hip name :P
Flip_Sim_Velocity_Broken_01.hipnc
Edited by TinFoil
I wrote velocity instead of viscosity
