Opacity Map not working!
I am using houdini 18.5.596 and V-ray core 5.10.20, it seems that when using opacity maps it does not working, i tried fiddling with some options it still does not work. doing that i figured out that when i start the render it works for a bit and then goes back to not using the opacity map, as you can see in the 2nd image. can someone help me with this.
Edited by stagnant_node
