Steadicam Posted November 22, 2021 Share Posted November 22, 2021 I was attempting to build a type of link system using the law of cosines and discovered that I need to use the "spherical law of cosines" instead for calculating this "spherical triangle" as seen below. I was already at the limit of my limited math-in-Houdini skills and was really hoping someone could help me approach this the best way to obtain the data/measurements needed. The simple image below represents a neutral position for three points. •Each point (A,B,C) is a fixed distance from the center of a sphere. Essentially creating a spherical triangle. •Each point only rotates about one axis between it and the center of the sphere creating angles •The A point is in a fixed position on the sphere and does not move. Consider it a kind of base point •The C point travels, with a limited range along the surface of the sphere(essentially rotating it's position from the center if the sphere). •The distance between A & B (AB) and B & C (BC) are both fixed lengths and function as arms. •The B point essentially functions as an elbow and always stays the same distance between both A & C respectively as the C point moves. Essentially I need C to be driven by XYZ rotations from the center of the sphere and for B to "chase it" like an elbow would "chase" a hand but within the constraints of it's single rotation and distances between A & C. Using the Law of cosines (or in this case the Spherical Law of Cosines) I should be able to measure the new distance of CA to find all the angles of A, B & C (in Radians?). https://en.wikipedia.org/wiki/Spherical_law_of_cosines Essentially a simple inverse kinematic that avoids using the Houdini bone system. Since A is always a fixed point I should the be able to simply compare the neutral angle of A to the new one and use that difference to drive the animation necessary to rotate both A and B to position the the BC and AB sides/arms to once again align with the new C position. I've included the scene below for reference but it's only a representation and the only potentially useful item is my measuring widget which unfortunately can't do radians at this point. Thanks for any help or pointers. Michael Law_of_cosines.hip Quote Link to comment Share on other sites More sharing options...
Steadicam Posted November 23, 2021 Author Share Posted November 23, 2021 Accidentally put this in scripting. Apologies to list moderators. Will repost in general if that is alright. Quote Link to comment Share on other sites More sharing options...
