PolyBevel Limited by surrounding edges?
fernandoreule
I'm trying to chamfer some edges in a cactus model and add the chamfer intensity as a parameter in the subtool.
Problem is, the edge behavior when being divided is either overlapping the smaller connections or limited by the minimum distance.
I've attached the same procedure in 3dsMax, for comparison, which is what I wanted.
Is there an easy way to make the polybevel behave like this?
Thanks!
Fernando Reule
  • 2 weeks later...
