Conkx Posted December 17, 2021 Share Posted December 17, 2021 Hi, I have a question about how to recover the name of a fbx object imported via "file" node in houdini that I export after having made modifications with the rop_fbx. Yes I could just rename the output with the name I want, the problem is that I import 50 objects in houdini that I export one after the other in one go thanks to the TOPs, there is a command in the output name that would allow me to retrieve this information ? thanks in advance Quote Link to comment Share on other sites More sharing options...
