Jack16277 Posted January 28, 2022 Share Posted January 28, 2022 (edited) Hello, I'm very new with Houdini, so the question might sounds silly to some, but I am trying to apply some Texture images through the Lopnet. This is how it looks in the viewport, but when I dive into the Lopnet, I apply the material but it won't show anything. Could I ask what am I missing here? Thank you Edited January 28, 2022 by Jack16277 Quote Link to comment Share on other sites More sharing options...
fsimerey Posted February 1, 2022 Share Posted February 1, 2022 You need to assign your material to your geometry. Check this video : at 4mn36s. He explain how to assign from materiallibrary node. You have 2 options: Assign from matreriallibrary node or add an AssignMaterial node. Quote Link to comment Share on other sites More sharing options...
Jack16277 Posted February 2, 2022 Author Share Posted February 2, 2022 (edited) Thank you for the solution, it did work! Although now I am having somehow a similar issue I have tried different forums/reddit, but I can't find solutions. I am working on a procedural landscape, and I am using Karma (I am following this tutorial https://www.sidefx.com/tutorials/the-complete-a-z-terrain-handbook/) I have two/three things that I would like to ask, but this one is probably the most problematic: I have created a rock with external softwares, mesh and textures. I have applied the textures creating the material and it seems to work well with Mantra and Karma. But when I use the Copy to Point, the texture disappears if I use Karma (it works in Mantra) MANTRA: KARMA: Forgot to mention that the textures works in Karma before the Copy to Point! Could it be a bug, therefore would it be better to switch to Mantra? I hope not since the script need Karma to generate the terrain (textures + displacement comes from COps and it shows only a flat plane in Mantra) Thank you again for your help (I am a bit clueless at the moment) Edited February 2, 2022 by Jack16277 Quote Link to comment Share on other sites More sharing options...
