jeantest Posted February 4, 2022 Share Posted February 4, 2022 Hello, I downloaded 3Delight for houdini 18.5.499 and even tho I tried with different versions of 3Delight when I try to create a Rop this message appears. Does anyone have an idea to solve it? Thanks! Traceback (most recent call last): File "_3dl_rop_3Delight", line 4, in <module> File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.499/houdini/python2.7libs\roptoolutils.py", line 10, in createRenderNode rop = hou.node('/out').createNode(rop_type, exact_type_name=exact_type_name) File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.499/houdini/python2.7libs\houpythonportion\ui.py", line 1081, in decorator return func(*args, **kwargs) File "C:/PROGRA~1/SIDEEF~1/HOUDIN~1.499/houdini/python2.7libs\hou.py", line 13130, in createNode return _hou.Node_createNode(self, node_type_name, node_name, run_init_scripts, load_contents, exact_type_name, force_valid_node_name) OperationFailed: The attempted operation failed. Invalid node type name Quote Link to comment Share on other sites More sharing options...
