gabor Posted February 25, 2022 Share Posted February 25, 2022 Hi, I'm trying to remove objects and collision objects from an RBD Bullet Solver simulation. Removing objects work inside the node connecting a geometry wrangle to the presolve output using 'removepoint' with the packed rbd geometry. I try to do the same with the collisions, but I'm not sure how to access the collisions from the geometry wrangle. I also tried the Collision Geometry input of the RBD Bullet Solver, and use a switch or move the geometry of colliders, but it does no seem to work. Any suggestions would be appreciated. Gabor Quote Link to comment Share on other sites More sharing options...
