Animating wave tank water level
I am new to Houdini (swapping from Realflow) and I have been trying to create a fluid simulation using the wave tank but have the water level move downwards over time, I tried to simply animate the "Water Level" value in the wavetank_initial but the simulation does not work as expected.
What would be the correct workflow in order to do this successfully?
Thanks in advance.
