Python - Running outside out Houdini
Houly
That is just for opening a hipfile from the python interface, be it a Hython console, python node, or executing a script with Hython from the command line.
Once you have the scene loaded, as in the examples on that page, you can access all of the objects within it to process.  I would suspect you aren't going to be needing to do this unless you are automating some pipeline stuff that needs to affect many files in succession and process them.
  • Thanks 1
Thanks Adam!! I'll try again.
