kwargs in Python SOP
Houly
This may be a unnecessary question.
The <kwargs> global dictionary variable does not working in Python Code(python) parameter,
which is the default parameter of the Python SOP.
# error code
Error
Python error: Traceback (most recent call last):
File "<stdin>", line 9, in <module>
NameError: name 'kwargs' is not defined
But interestingly, if I create a additional string parameter and call <kwargs>, it returns a valid value.
(The node is accessible via hou.pwd(), but it's just a curiosity that has nothing to do with actual use.)
Why doesn't <kwargs> work normally in Python Code(python) parameter?
I wonder what the difference is between the two.
Thanks in advance for the reply!
