Justin K Posted May 16, 2022 Share Posted May 16, 2022 I have a null, with some string parameter. The first is a file directory parameter im using to get file paths and update them quickly. Is there a way in hscript to take just the last folder name from this string, and generate a new parameter from that? Example: directory-- D:/MEGASCANS_LIBRARY/Downloaded/surface/stone_floor_vixidai extracted string one--stone_floor_vixidai extracted string two--vixidai the first part of the string D:/MEGASCANS_LIBRARY/Downloaded/surface/---will never change. its just that last path. Thank you! Ive attached an image which should make it clear. Thanks!!! Quote Link to comment Share on other sites More sharing options...
