Renderman subdivisions not displaying in Solaris
microbe
Renderman 24.4 in Houdini 19.0.589 can display polygons as subdivision surfaces in OBJ context,
but not in Solaris. If I create the geometry in OBJ and import it into Solaris, Karma renders the expected smoothing but not Renderman.
Suggestions would be greatly appreciated.
Mark
[SOLVED] Renderman subdivision issue
I worked through the LOPS tutorial by Rohan Dalvi ( https://www.youtube.com/watch?v=QqE4HYFDbGk), although not focused on Renderman, helped a lot.
I made sure to add the "render polygon as subdivision surfaces" parameter
to the parameter panel, and checked it when appropriate.
