Help simulating an ice cube melting at the edges
Jmg07
I have modelled an ice cube using rbdmaterialfracture and it looks pretty good.
But there is no condensation or melting that you might expect if you left an ice cube out for 5-10 minutes (assuming you're not in a place where it's close to 0 degrees).
I tried to group some of the chipped pieces and use that as a flip source - but every time I used the flip source - it turned the whole cube into a volume.
I couldn't really find any tutorials specifically on adding details like melting to specific pieces.
If anyone has links or advice that would be great.
Thanks
