Tearing & Deforming Metal using RBD
mahesh
Hi, can anyone help me achieving the following:
I have a metallic cube, and a simple emitter shooting spheres at high rate at it.
I have Glue constraints turning to Soft constraints, also using rbd constraint from rules and rbd constraint properties. I can achieve denting(deforming) of that metallic cube, but I can’t achieve destroying it completely by tearing it to pieces all over the place. No matter what I do the steel cube just keeps deforming inwards like a wax or rubber and it seems like I can’t break Soft constraints holding pieces together. I tried using bullet rbd solver with break thresholds set to some super low values but it still won’t break/tear off.
