reproduce result of copy stamp: drive scale with custom attribute
Hi - you can use a foreach point loop if you wish to use a point attribute to drive certain paramters for each copy. Although in your case you're trying to control the scale of the copies, so a faster + less expensive (computationally) way would be to directly set the pscale of the source points using that attribute, and avoiding foreach loops. I've demonstrated both methods if it helps.
old_tutorial.hiplc
