Can Initialize A Variable To A Channel Value In The Vfl?
BrianK
I'm writing a VEX shader that references about 20 objects in about 20 places in the shader. For instance, the variable startP is set to "ch("/obj/WE1/tx")".
Is there a way I can do all this channel referencing in the VEX code so that it's all setup when I drop the shaders, or does it have to be done through the GUI (or hscript)?
