Notus Posted June 30, 2023 Share Posted June 30, 2023 Hey peeps, I have a HDA im working on that is using python to create nodes within the HDA. It all works fine when unlocked, but i would prefer to keep it locked if at all possible. The error is simply: "PermissionError: Cannot create a node inside a locked asset" Cheers for any help Quote Link to comment Share on other sites More sharing options...
lynloveyounever Posted July 6, 2023 Share Posted July 6, 2023 (edited) Rightlick the HDA, open the Operator Type Properties window, and find Node page- "Editable Nodes", Pull a child node name into there (for example, the subnetwork node). that is mean, whatever you asset lock or not, you always allowed to edit that node. You can Understand by this page in Houdini offical help: https://www.sidefx.com/docs/houdini/ref/windows/optype.html#:~:text=the voxel size.-,Editable Nodes,-A space-separated Edited July 6, 2023 by lynloveyounever 1 Quote Link to comment Share on other sites More sharing options...
