Parameter dialog bug
MacOS Ventura, Apple silicon. Does not happen on Windows.
If you have more than one pinned networks with different contexts (/OBJ, /MAT, /OUT),
and you are using Parameter Dialog instead of showing parameters in a separate pane,
sooner or later switching between the tabs leads to an empty or corrupted Properties dialog (see the attached image).
Has anyone encountered this bug?
