sibarrick Posted May 17, 2007 Share Posted May 17, 2007 Does anyone know any tricks to getting omsbind to work at object level for an asset. I can use it fine for sops but doing this for an object doesn't seem to work omsbind -t obj highlight objselect "First input" "Select the target null" 0 1 all 0 "" 0 omsbind -t obj highlight objselect "Second input" "Select the viewing camera" 1 1 all 0 "" 0 when I try to change my selection through the viewport it just treats my object as if it were a normal object and all I'm able to do is pick a parent. I need to get the user to pick a parent and a second input. Also, running omsls -t obj doesn't actually list any available selectors for objects, so the objselect part just comes from the example in the help omsbind -t obj blend objselect "Second Input" "Select the second blend input" 1 1 all Binds a simple object selector to the second input of the blend object. H8.2.13 Quote Link to comment Share on other sites More sharing options...
