ryan_harrington Posted May 11, 2024 Share Posted May 11, 2024 I'm really not having an easy time adapting to Solaris...so you might need to explain like I'm five. I have a RedshiftRendeSettings node that sets up all the usual AOVs, It's writing multiple frames, it's fine. Above that node I have a renderVars node that sets up the cryptomatte. I tested a bunch of single frames and only when I submitted the big render did I realise that it's only writing one frame of that seperate AOV output. This is the output path on that renderVars node (the @EYE strings are custom pipeline wrangles): q:/`@EYE_g0_name`/Build/`@EYE_g1_name`/`@EYE_g2_name`/`@EYE_g3_name`/render/3d/`@EYE_element_type`-`@EYE_element_name`_v`padzero(3,@renderversion)`/`@passname`/CRYPTO.$F4.exr it looks like it's continually overwriting this frame: CRYPTO.0250.cryptomatte.exr 250 is the end of the frame range in the USD ROP As I step through the range in solaris, the output path in the scene graph reads correctly for the renderVars and the current frame...so it might be globally overwriting that path as it runs through the time-range for every frame of the USD write. Greatful of any help! Quote Link to comment Share on other sites More sharing options...
