Jmg07 Posted June 10, 2024 Share Posted June 10, 2024 Hi, I'm just following a tutorial on the sidefx site about making a soccer ball and in the uv step, used a uv flatten node, and it's all good, except that on the underlying texture there is a logo that doesn't line up proprely. So i want to move one of those white uv shells into position so that the logo is in the middle of one of the panels of the ball. But I cannot work out how to move a shell. I tried all the different gizmos and handles, etc. but nothing worked. Help pls. Quote Link to comment Share on other sites More sharing options...
RobiDoes3d Posted June 11, 2024 Share Posted June 11, 2024 Hi jmg07, you can use uv edit, or uv transform. Next to the group field, there is a little arrow icon. You can press that and select the shell you want to move and press enter. Hope that helps. Best regards, Robert. 1 1 Quote Link to comment Share on other sites More sharing options...
