sprawd Posted June 9, 2007 Share Posted June 9, 2007 I try to complie the source file "Flatten SOP" houdini provided, below are the steps : 1.instrall HDK 2.create a empty projection in .NET 2003 3.load SOP_Flatten.c and SOP_Flatten.h respectivly 4.compling .... the output said D:\Program Files\Side Effects Software\Houdini 8.1.655\toolkit\include\SYS\SYS_Math.h(116): fatal error C1083: cannot open include file : Quote Link to comment Share on other sites More sharing options...
sibarrick Posted June 9, 2007 Share Posted June 9, 2007 (edited) You don't need steps 2-4 Just open a command line and navigate to flatten.c and type hcustom flatten.c Also, make sure you have the right environment variables set up You need MSVCDir pointing to the Vc7 directory of the .NET installation And these added to your path - change the path to your install directory obviously C:\PROGRA~1\MICROS~1.NET\Vc7\bin; C:\PROGRA~1\MICROS~1.NET\common7\IDE; Edited June 9, 2007 by sibarrick Quote Link to comment Share on other sites More sharing options...
sprawd Posted June 10, 2007 Author Share Posted June 10, 2007 (edited) Hey sibarrick: .. .very very appreciated... I really hope begin coding for houdini as soon as possible..... when I use "hcustom", new questions appeared: I type "hcustom -I . SOP_Flatten.C" (this file is in the dir "..\Houdni\toolkit\samples\sop") and output is: Making 'SOP_Flatten.o' from 'SOP_Flatten.C' Microsoft Edited June 10, 2007 by sprawd Quote Link to comment Share on other sites More sharing options...
sibarrick Posted June 10, 2007 Share Posted June 10, 2007 Yes debugging in HDK is fun! lots of cout statements is about all I can suggest, others may know better. The paths need adding as environment variables, right click on my computer and go to properties -> advanced -> environment variables and add them in there. Quote Link to comment Share on other sites More sharing options...
sprawd Posted June 10, 2007 Author Share Posted June 10, 2007 (edited) Thanks a lot.. your reply is so fast... , I was always editing my post... I did all things following your directing... and it is seemly work, the output is: D:\Program Files\Side Effects Software\Houdini 8.1.655>hcustom SOP_Flatten.C Making 'SOP_Flatten.o' and 'C:/DOCUME~1/LiJian/MYDOCU~1/houdini8.1/dso\SOP_Flatt en.dll' from 'SOP_Flatten.C' Error running cl Argument list: 0: cl 1: -TP 2: SOP_Flatten.C 3: -DUT_DSO_TAGINFO="3262197cbf3e403e2aa703a84b30d1a27510bfd3c02fc9ad3ff39918 5844bbcc7bad308e9f583c7a4357bda875c82b0f58f4e709efd0e954443c3df877ea81ac5bbe45e2 a6884994cf6fe74106f43b" 4: -TP 5: -Zc:forScope 6: -DVERSION=8.1.655 7: -DOFSTREAM_PERMISSIONS=, 0666 8: -DI386 9: -DWIN32 10: -DSWAP_BITFIELDS 11: -DDLLEXPORT=__declspec(dllexport) 12: -I 13: . 14: -I 15: D:/PROGRA~1/MICROS~1.NET/Vc7/include 16: -I 17: D:/PROGRA~1/MICROS~1.NET/Vc7/PlatformSDK/include 18: -I 19: D:/PROGRA~1/SIDEEF~1/HOUDIN~1.655/custom/include 20: -I 21: D:/PROGRA~1/SIDEEF~1/HOUDIN~1.655/toolkit/include 22: -Ox 23: -MD 24: -GX 25: -GR 26: -DSESI_LITTLE_ENDIAN 27: -DMAKING_DSO 28: -FoSOP_Flatten.o 29: -LD 30: -link 31: /libpath:D:/PROGRA~1/MICROS~1.NET/Vc7/lib 32: /libpath:D:/PROGRA~1/MICROS~1.NET/Vc7/PlatformSDK/lib 33: D:/PROGRA~1/SIDEEF~1/HOUDIN~1.655/custom/houdini/dsolib/*.a 34: -out:C:/DOCUME~1/LiJian/MYDOCU~1/houdini8.1/dso/SOP_Flatten.dll Is it right? But I can not find compiled resoults, where is it? How to use that in houdini? thanks very much Edited June 10, 2007 by sprawd Quote Link to comment Share on other sites More sharing options...
sprawd Posted June 11, 2007 Author Share Posted June 11, 2007 "Error running cl"?? still have problem..I could not fix it.. I try to run a batch file from the houdini command line tools... set path=%PATH%;D:\PROGRA~1\HOUDIN~1.655\bin;D:\PROGRA~1\HOUDIN~1.655\toolkit\bin set HOME=c:\temp\home set HFS=D:\PROGRA~1\HOUDIN~1.655 rem set SESI_TAGINFO=" : sprawd 2007" set MSVCdir=d:/Progra~1/Micros~1.net/vc7 call D:\progra~1\micros~1.net\vc7\bin\vcvars32.bat but there are no changes on the output... help me...THANK! THANK! Quote Link to comment Share on other sites More sharing options...
