NikWG Posted July 8, 2024 Share Posted July 8, 2024 (edited) Hi ! We use houdini as primary software in connection with pipeline management system Ftrack. It used to be ok for a long time, but not that long ago something went wrong. Houdini being started from ftrack launcher generates endless stream of errors like this But when Houdini is started directly without ftrack - everything goes fine I understand, that it regards ftrack plugin/scripts, but I can not define what script may invoke such behavior, because houdini freezes at this moment May be somebody faced such errors or just may give an advice where should i start digging from. setting HOUDINI_UI_QUEUE_SIZE does not help.... Houdini 20.0.751 py3.9 Ftrack Connect 2 Py3.9 Thanx in advance !!! Edited July 8, 2024 by NikWG Quote Link to comment Share on other sites More sharing options...
